TDS calculation line wise
Dear All,
This is vinayak from mumbai. Could you please help me out on below issue…when i charged TDS on one invoice in different way i.e one is from interest and another is from contractor.but when i check in statistics option its shows total tds calculate in both the lines.
I would like to see the separate calculation in each line TDS calculated. This will help me to clear the each line transaction how much TDS calculated.
Vinayak
Welcome to DUG!!!
On Statistics it will show the total TDS only
On line level there is one field in table called TDS Amount .Kindly enable that on form so you will get line wise TDS Amount
Thank you very much. i did and it works.
Welcome
If it resolved your problem then verify the solutions so it will help others…
