TCP/IP error ETIMEDOUT
ERROR ( there was a time-out in an attempt to establish a connection with the server (TCP/IP error ETINEDOUT) I am able to reach the database server from client but while connecting to client from database server i am getting this error message can any one help
In the Open Database Box, there will be a tab Advanced, click on that.
Check NET Type: Set-it to TCP and if you are using on SQL Server, then make it Default.
I hope this will work… otherwise it will be your network problem…!!!
