Is it possible to make table 78 “Printer selection” contain data per company instead without destroying vital functionality??! Anyone tried it out?? Kind regards bc
What would you win by doing this? Lars Strøm Valsted ------------------------- Why can’t programmers tell the difference between Christmas and Halloween? Because OCT(31) = DEC(25)
Two different companies can print the same report on two different printers.
You can turn “data per company” to yes, and recomplie the whole database. Or, just add a field with a company name in it, as it makes it more flexible (blank=all companies, filled in - company specific) and accessible from all points in the DB. Then, some coding needs to be done (CU1 to be exact) to make the system pick a right printer. Alex
