Tax Calculation Problem
Hi All ,
I have a query ,
i have to calculte the tax like this
baseamt :1000
service tax : 7.2 % of base amt
VAT : vat 12.36 of 75% of base amt (means 750).
any one has idea what base formula i should use to acheive this.
Shailesh
Make the standard deduction to 25 % in the tax details for calculation of 75% on the Invoice Base amount.
regards
Rahul
Hi Rahul,
i have done this standard deduction to 25 % in Tax Detail Table but it is not working , any thing i have to do in structure for this.
Shailesh
It will calculate by the same process.
Set the service tax %age and vat %age in the respective fields and mentioned the 25% in the standard deduction for its tax calculation.
One more thing, check whether the tax liable is checked or not in the customer/vendor card.
Regards
Rahul
Hi Rahul,
Tax is calculating but , service is correct, but the Vat amount is coming on base amt instead of 75
% of base amount, aftre putting the standard deduction to 25% still the tax is calculating on actual base amt instead of 75% base amt.
Shailesh
Has any one solve this type of issuse.
Instead of defining the Standard deduction % in Tax Details,define it in Tax Area setup and it will work.
Regards
Ratheesh
Understand the functionality of Non ITC Claimable Usage % .It will calculate.
Hello Ratheesh,
In which feild i have to define the Value in Tax Area setup
shailesh
Hi Amol,
Where I will find this Functionality of Non ITC Claimable Usage %.
regards,
shailesh
