When i run the task recorder tool in AX 2012 the following error is generated
Method ‘styles’ is not supported by the Automation interface of the COM object of class ‘_Document’.
Please help me out
Thanks a lot in advance
not sure of that but found that this link may be beneficial for you… http://dynamicsuser.net/forums/t/40499.aspx
What was the action you performed when you got the error? If you were generating a document, what’s the version of your Office?
Thanks a lot for reply
Actually i was trying to generate a Doc., and i can see the error generated
But in the C drive task recorder folder the Doc. and video files are generated
so its solves my problem
Once again thanks for the concern
