Target Date not found in Work Calendar? in AX2009
In my new sales order creation using workflow i got the error " Target Date not found in work calendar" and also status option shows “Stopped(error)” in new sales order transaction.
Configured time approval in workflow configuration also then also same error prompt in Action–> view History in my workflow.
Am new to dynamics. Pls reply ASAP
Thanks in advance
Make sure that periods exist for your work calendar for current dates or setup workflow configuration not to use the calendar (Select Non-calendar).
I’ve seen the same error before and I’ve just documented it for you - see Target date not found in work calendar on my blog.
I can’t guarantee that your problem is exactly the same, but hopefully it’ll give you some pointers, at least.
