Hi to all!
I’m trying to calculate the taxcode with navision.
I’m almost done , but i have a little problem:
I have to take a value (code) from a field in a variable type record and use this value to calculate taxcode.
I’ll explain:
I have a table “comune” that has three field: IDRECORD,IDPROV, CODE and DESCRIPTION.
This table is related with another table , so I can filter some fields .
In the form I have:
textbox provincia where I select IDPROV
textbox comune where I select a DESCRIPTION related to IDPROV
the tax code has to take field CODE from table “comune” when comune is selected, and put this value, in a variable type text , so it can be calculated.
I tried with function GET, but it doesn’t work.
How can I do that?
If I understand your requirement correctly…
you select IDPROV from Comune table
You select DESCRIPTION from Comune table
Code value from Comune table has to copied to a text variable…
If so,
write below code in Onvalidate field of Description field
Comune.RESET;
Comune.SETRANGE(IDPROV,provincia);
Comune.SETRANGE(DESCRIPTION,comune);
IF Comune.FINDFIRST THEN
Textvariable := Comune.Code;
BTW, what is your primary key in Comune table?
I Select IDPROVINCIA from another table called Provincia.
Then I select Comune from table Comune , comune field is filtered with a table relation,
example:
table provincia
idprovincia descriptionprovincia
AB text1
CD text 4
EF text6
Table comune:
IDPROV descriptioncomune code
AB text1 C123
AB text2 C456
CD text3 D123
CD tex4 D456
When in the form i select AB from table provincia, in textbox comune I see only descriptioncomune that have IDPROV = idprovincia
Now, I don’t have to choose code from table comune through a lookup table, but I need to get that field and put it in the variable Textvariable.
So, I have to use FINDFIRST function?
Is there any chance of
Table comune:
AB text1 C123
AB text1 C456
if yes, which value you want?
If you use Findfirst, it will give you C123.
Table comune:
AB text1 C123
AB text2 C456
I would have value “code” near the field selected.
E.g.
if I select text2, I wolud have code C456.
what is the problem with this code/
Comune.RESET;
Maybe I exposed my problem in a wrong way.
So, I’ll explain:
I have a form, who’s source table is the codicefiscale table.
This form has to calculate a tax code, so , if I insert Name, Surname, Date of Birth, BirthPlace I’ll obtain, with an algorithm, the taxcode.
When I choose the birthplace, i choose first the province from the provincetable, and then the town, from the town table (comune).
this two elements are related each other trough a table relation in codicefiscale table (the source table of the form )
When I choos the town, in the table town I have fields descripted above.
Then, when I press Calculate button, I have to catch the value in the field “code” of the town table (who’s name’s “comune”) that I have selected.
With the code that you suggested, nothing happens.
I have not understood where, why and how implement this.
Thank you
Luciana
If I understand Correctly…
In Comune Table, IDPROV is birthplace and DESCRIPTION is town.
If Yes, Write the code onPush Trigger of Calculate.
Comune.RESET;
Comune.SETRANGE(IDPROV,birthplace);
Comune.SETRANGE(DESCRIPTION,town);
TaxCode := Comune.Code;
Message(’%1’,TaxCode);
