Tabular layout in MorphX report
Hi Guys…
Can anyone tell how to design a report in tabular structure with multiple columns and rows in ax 2009?
i know to work on SSRS but in morphX i dont how to design in table layout…
please anyone help…
Thanks in advance…
I suggest you create a report through wizard (Tools > Development Tools > Wizards > Report Wizard) and review the generated report. It will show you how to do basic things. If you need something specific, you’ll have to explain your problem to us.
Nevertheless note that MorphX reports are already deprecated, therefore learning them isn’t the best investment. If you’re familiar with SSRS, maybe you should simply create an SSRS report. (Both AX 2012 and AX 7 utilize SSRS.)
Okay Martin. my need is i want create a report in grid view with multiple rows and columns. for that i used some property tools like line above>solid,line below>solid,line right>solid, line left> solid… but the alignments are not in proper position… i want to print the data in grid format. like a table.
