Tabledata does not exist after renaming the table
i renamed the existing table with some new object id(original id is 70000 and renamed to 70001) . after renaming i compiled the object it is compiling without error. but when i try to run the table its showing error as “tabledata 70000 doesn’t exist”. so how to run that table without error
i tried to insert data its working fine. if i change the object id to old id 70000 then its is working fine. but i need to rename the object plz help me out
Remove the record from Object Metadata table for table 70000 and then rename the table and compile
