i have list project sales orders. I need to display Invoice Id in the report each line of sales order. I found the invoice id available in the ProjInvoiceJour tale but there there is no direct relation between salesLine and ProjInvoiceJour.
I need to add this in existing query output. Please find below query and let me know relation between above mentioned table?
SELECT
s.DATAAREAID, s.CUSTGROUP, s.SALESGROUP, s.INVENTLOCATIONID,
s.INVENTSITEID, p.PROJID, s.SALESID, '' as InvoiceNo, cps.DELIVERYDATE,
s.SALESNAME, s.CUSTACCOUNT, wi.FilterCode[4], tist.tmxInventStatusName, sl.ITEMID, sl.NAME, '' as Brand, cps.QTY, sl.SALESPRICE,
s.CURRENCYCODE
FROM
ProjTable p
JOIN
SalesTable s ON p.ProjId = s.ProjId
AND p.DATAAREAID = s.DATAAREAID
JOIN
SalesLine sl ON s.SalesId = sl.SalesId
AND s.DATAAREAID = sl.DATAAREAID
JOIN
CustPackingSlipTrans cps ON sl.SalesId = cps.SalesId
AND sl.LineNum = cps.LineNum
AND sl.ItemId = cps.ItemId
AND sl.InventTransId = cps.InventTransId
AND sl.DATAAREAID = cps.DATAAREAID
LEFT OUTER JOIN
InventTable i ON sl.ItemId = i.ItemId
AND sl.DATAAREAID = i.DATAAREAID
LEFT OUTER JOIN
WHSInventTable wi ON i.ItemId = wi.ItemId
AND i.DATAAREAID = wi.DATAAREAID
LEFT OUTER JOIN
tmxInventItemStatus tiis ON i.ItemId = tiis.ItemId
AND i.DATAAREAID = tiis.DATAAREAID
LEFT OUTER JOIN
tmxInventStatusTable tist ON tiis.tmxInventStatusTableRef = tist.RecId
LEFT OUTER JOIN
MAX_ItemCostView micv ON i.ItemId = micv.ItemId
AND i.DATAAREAID = micv.DATAAREAID
where
s.DATAAREAID = 'MTL'
and s.CUSTACCOUNT not in('MTL-003619','MTL-003686','MTL-003676',
'MTL-003620','MTL-003645','MTL-006710','MTL-003800', 'MTL-002907','MTL-002906',
'MTL-002908','MTL-003677','MTL-006711','MTL-006719','MGC-001242',
'MGC-001227','MGC-000186','MGC-001235','MGC-001238', 'MGC-001250',
'MGC-001822','MGC-001228')
And ((cps.DeliveryDate>={ts '2020-02-01 00:00:00.000'} AND cps.DeliveryDate<={ts '2020-02-05 00:00:00.000'}))
