I have created one SSRS report. In my side, it is working fine, but one user getting the below error message.
The user ‘[Username]’ is not authorized to select or save in table ‘[Table name]’. Demand refused. Impossible to select or save in table ‘[Table name]’. Access refused.
Can you please help me how to solve this issue?
Hari
Hi Anand, Thanks for your reply. That table AOSAuthorization property value is None in the development environment. I didn’t change this property. Thanks, Hari
In that case try changing the “maxaccessmode” property on the table to delete.
Sorry, i can’t find this maxaccessmode table property. FYI: I am using AX 2012 R2.
DictTable dt;
dt = new DictTable(tablenum(yourtable));
if (dt)
print strfmt(“Maximum Access Mode: %1”,dt.maxAccessMode());
Try to retirieve the maxaccessmode through the above code snippet.
I am getting this message “Maximum Access Mode: Delete”
You must have created a Privilege for this report. So add the required table in Tables node under Permissions in the privilege.
