Hi, everybody! Does anybody know if it is possible to view list of keys for some Record variable in Symbol Menu, like it is done for Field names? It seems that is not possible (you should go through Object Designer → Tables → Keys, etc.) to copy it), which is inexplicable.
if you are working in reports, just add a new dataitem with the desired table, so you can set and copy the key on the DataItemView. If cou work in Forms, you can just change the source table and set and copy the key from the SourceTableView. You can not get the key as you does in 3.5x. it is one of the best, so let us make it the best at all
10x, Rene
