Tab Order - Page
Hello,
Is there any possibility to set the tab order on a page?
I know that I can set it with NextControl property on a form, but what about a page?
Thanks in advance,
Frida
Yes, we can
Open Item Card and Select Customize this page from top right corner
Select Fast tabs…
Here you can Move up and Down aS you wish
Thanks for your answer.
It seems, I couldn’t described my problem correctly.
I don’t want to set the FastTabs. I want to change the sequence of controls pressing the tab button. The “default tab order” on a page is from top to bottom starting in the left column and then the right coloumn on a FastTab. I would like to change this sequence if it is possible.
I think the answer is no…
You have to adkust the fields in page as you want…
