T-FV-2001 Invalid Batch Header Record Length
hi all
I found this error message when i validate etds using FVU .
T-FV-2001 Invalid Batch Header Record Length.
Please suggest me what should i do and how i came out this error message…
Ya. I have solved this issue. If you have solved it then good. Else I can help you out for solving this problem. This problem may have occured during validation of file.
Pl. give me solution
Hey Manish,
I would be glad if you could share the solution.
There are two ways of validating file -
  1. Either change validation during file checking
  2. Or change file content according to validation already present in Navision and its masters
Manish
Hi Manish
Please elaborate that how to change file content according to validation already present in Navision and its masters. As
TDS/TCS - ERROR FILE
Line No
Record Type
Statement Type
Field Name
Challan Details Record Number
Deductee/ Salary Detail No.
Error Code & Description
2
Batch
Regular
NA
Hi Satyam,
Need to know if you’re Technical or Functional Consultant or end user?
I would also like to know about steps you’re following to solve your query.
Debugging is only solution to identify your issue. This will clear if Master in Nav needs change or object to be modified to generate appropriate output (as per annexure)
