System.NullReferenceException: Object reference not set to an instance of an object
I have installed CU8 on AX 2012 R2
On Software Update Check List
When i run Pre synchronize -->> DataUpgrade CocKPit
i face the following Eroor
System.NullReferenceException: Object reference not set to an instance of an object.
at Dynamics.Ax.Application.ReleaseUpdateExecute.Run() in ReleaseUpdateExecute.run.xpp:line 36
at Dynamics.Ax.Application.BatchRun.runJobStaticCode(Int64 batchId) in BatchRun.runJobStaticCode.xpp:line 54
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 13
at BatchRun::runJobStatic(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at BatchIL.taskThreadEntry(Object threadArg)\
Please tell us what code you have at line 36 of ReleaseUpdateExecute.run().
