I’ve built a class to loop through customers, pass a customer’s order to an AX report, save that report to PDF, and mail that report to the customer.
It works except for it seems that when I attach the pdf to email, AX keeps the file open so I can’t delete it or override it. Here’s my mail code. How can I release the file from AX?
Error is "Error opening the file “file here”. The file is write-protected or in use.
System.Net.Mail.MailMessage mailMessage;
System.Net.Mail.Attachment attachment;
System.Net.Mail.AttachmentCollection attachmentCollection;
System.Net.Mail.SmtpClient smtpClient;
System.Net.Mail.MailAddress mailAddressFrom;
System.Net.Mail.MailAddress mailAddressTo;
str Body;
str Subject;
str SMTPServer;
str FileName;
FileIOPermission perm;
mailAddressFrom = new System.Net.Mail.MailAddress("","");
mailAddressTo = new System.Net.Mail.MailAddress("","");
Body = “Test of some orders automatically emailed.”;
Subject = “Test Backorder send Batch AX”;
SMTPServer = SysEmailParameters::find(false).SMTPRelayServerName;
mailMessage = new System.Net.Mail.MailMessage(mailAddressFrom, mailAddressTo);
mailmessage.set_Subject(Subject);
mailmessage.set_Body(Body);
attachmentCollection = mailMessage.get_Attachments();
FileName = _fileName;
perm = new FileIOPermission(FileName,‘r’);
perm.assert();
attachment = new System.Net.Mail.Attachment(FileName);
attachmentCollection.Add(attachment);
smtpClient = new System.Net.Mail.SmtpClient(SMTPServer);
smtpClient.Send(mailmessage);
// recommend that you still call revertAssert after invoking the protected API to limit the scope of the assert.
CodeAccessPermission::revertAssert();
