When we add field in dialog like :
dSchemeCode = dialog.addField(extendedTypeStr(SchemeCode), “Scheme ccode”);
we get a system generated name like Fld1_1 for this control .
Is possible to change this System name to SchemeCode ?
Not without a change in DialogField class, especially in fieldName() method.
Please explain how to use fieldName() method in order to give ID to a field located inside a dialog.
You can see that fieldName() is what defines the control name:
str fieldname(int arrIdx = 1)
return #PrefixField+int2str(fieldNo)+'_'+int2str(arrIdx);
You will have to return another name from there. You’ll also need a way how to pass the required name to DialogField, store it in an instance variable and extend #CurrentList so the variable is packed/unpacked properly.
