System labels
Hi is there a way to know what does @SYS181024 contain
thanks in advance
Sure. Go to Tools > Label > Label editor in AX 2012 developer workspace, put the label ID to Find what field, choose the language and press the button.
Thanks Martin It was of gr8 help … happy weekend
In AOT write a job, info("@SYS181024"); then you can get the label text also.
vinesh, if you’re satisfied with the answer, please mark it as Solution, so others see that the problem is resolved.
Sure martin will do that here on …thank you
Thanks tony …
