System force page break in a report
We have a big information report that should print 2 pages with text for each object. But it “break” in the middle of the text… is this because the a4 format is to short and attain dont understand that it should jump on to next page? Any suggestions close up to the new year? [^]
Hi Do I understand you correctly that the text on the report does not wrap onto the second line? If that is the case, you need to set the property of the control box to Multiline = Yes and you need to increase the size of the control box itself. Let me know if you don’t come right.
We have the following problem: In the body section on a report we have to print a lot of fields that streches over more than 1 page, but the report just cuts afte one page, and does not print the fields that exceeds what can be placed on one page. Any solution
Hello, as i understand it, system should reach end of the section and after it must perform page change properly. By the way, does your text supports paragraphs? You can change sections width to the narrower size. It is very interesting " http://www.navision.net/forum/topic.asp?TOPIC_ID=3951&SearchTerms=multiline ". It is interesting in some kind " http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=9022 ". And did you check option ‘KeepWithNext’ of the last section before page break? BR, Anthony
Hi Frodio
quote:
In the body section on a report we have to print a lot of fields that streches over more than 1 page …
If I understand it right, your body section is longer than the page. This can’t be broken from navision ! you should use a construct with the number-table to shorten the body.In best case to 1-line long bodies. if the bodies are greater than there is often some miscalculating of page length an the page is not properly filled
I’m not sure I understand the problem. Is Navision cutting the fields horizontally or vertically? If horizontally, have you tried to set the Orientation to Landscape?
Hi Frode, I think people would like to help, but please try to define what the problem is.
