System field 'Created By' does not populate value
In a customized form, system fields “Created By” ,“Created Date”, “Modified By”, “Modified Date” fields are displayed. When a new record is created sometimes these fields does not have any value. What could be the issue ?
Also, the data source’s method ‘ModifiedField’ is overridden at table level for a date field. When value is entered for this date field, the system fields does not get populated, otherwise the system fields getting populated.
Raghav.
Hey,
I found the cause of issue. The system fields are overwritten. Hence the "CreatedBy’ and other system fields field were blank.
Raghav.
Hi Ragavandra,
I am also facing the same problem !! Can you tell me how did you fixed it.
Santhosh Kumar.
Hi Santosh,
I have mentioned the root cause. If the system fields are overwritten then the values will not be populate automatically. The values need to be updated via code.
Raghavendra
Hi Raghavendra,
Thanks!! It worked… :slight_smile:
