I get a compile error in SysReportLibraryExport class.
It’s the last error after upgrade from V4
Anyone have any suggestion?
The above “click here” that Harish posted no longer directs to the solution (the BusinessSolutions/newsgroups thing must’ve changed up a bit since Harish originally posted this). Furthermore, I can’t even re-create a successful query on the site - it’s like the answer was removed.
Would love to know the solution to this. I understand it’s likely due to our production SQL server being installed on a separate server than our production AOS.
We don’t see this error in our dev and test environments where everything is installed together on the same server.
Ok, I finaly found this answer on Adus Riyadi’s blog:
It turned out that I had to compile the class by opening Ax client from database server as there is where the reporting extension is installed.
Ok, found Agus Riyadi’s blog:
This indeed worked for me:
