SysReferenceTableLookup and CustomerDataInteractorFactory
On a regular SysTableLookup against CustTable you can use the “CustomerDataInteractorFactory::resolveAmbiguousReferenceForControl” to help you on the lookup.
So typing customer name filter the lookup by name and if you type customer number it filters the lookup by number.
From the CustTableLookup form I can see that there is support for the segmented entry and formstring.
Is that possible with referenceGroup?
