SysDictTable is not synchronized.
Hello.
Hello,
I have run into a problem in the standard code (which I didn’t change it, and I don’t understand why is the problem) on SalesPurchJournalSelect.setJournalHeader_allowEdit()
Here is the code :
protected void setJournalHeader_allowEdit()
SysDictTable dictTable = new SysDictTable(this.journalHeader_ds().table());
Counter i;
FormDataSource fds = this.formDataSourceAll();
for (i=1; i<=dictTable.fieldCntWithoutSys() ;i++)
this.journalHeader_ds().object(dictTable.fieldCnt2Id(i)).allowEdit(false);
fds.object(dictTable.fieldCnt2Id(i)).allowEdit(false);
For the line :
I got (when i=37) the exception of null object (And that is the first field I added to the table PurchParmLine).
I have tried to do synchornize, also delete the new fields and add them again, but still the same problem.
I see that fields are on sqlDictionary with appropiate index, but on :
this.journalHeader_ds().object(dictTable.fieldCnt2Id(i)) the object is null.
  • but I cannot see what may be the problem cause (Why SysDictTable is not synchronized with my table).
Thanks :slight_smile:
Welcome to DUG [:)]
You posted in the wrong forum. I will move it to DAX Developer forum for you…
Except that I can’t move this thread. Will ask the admin to do this.
