installed the GLS layer for Poland (the same page with SP1, but the link is a little bit lower)
SP1 RU7
after this my synchronize Data base its shows
I had 10 dimensions on INVENTSUMDATEFINANCIALDIM_RU table
Cannot execute a data definition language command on ().
The SQL database has issued an error.
Object Server 08: The database reported (session 3 (Admin)): [Microsoft][SQL Native Client][SQL Server]The index ‘I_9557DIMIDX’ on table
‘INVENTSUMDATEFINANCIALDIM_RU’ has 17 column names in index key list. The maximum limit for index
or statistics key column list is 16… The SQL statement was: "CREATE INDEX I_9557DIMIDX ON INVENTSUMDATEFINANCIALDIM_RU (DATAAREAID,INVENTSITEID,INVENTLOCATIONID,INVENTPROFILETYPE,INVENTPROFILEID,DIMENSION,DIMENSION2_,DIMENSION3_,DIMENSION4_,DIMENSION5_,DIMENSION6_,DIMENSION7_,DIMENSION8_,DIMENSION9_,DIMENSION10_,ACCOUNT,STORNO) "
Has anyone come across such message before? How to resolve this?
I don’t believe it’s broken in the standard application (although I can’t verify it), more likely you have some additional fields there. Does “I had 10 dimensions” mean that you have some code in higher layers? If yes, you should upgrade your code at first. If not, look to the table’s metadata to understand where all those fields came from.
By the way, can’t you just disable the Russian functionality? I expect that INVENTSUMDATEFINANCIALDIM_RU is Russian but you mentioned Poland only.
I am doing the Upgrade
Actually for upgrade
1.take the application files and data base
2. install Ax 2009 with sp1
and paste the application files to AX 2009 Instance
after that i started the AOS( http://dynamicsuser.net/forums/p/47426/240869.aspx#240869)
but this one for Poland That’s y i taken the Based on the link
