Synchronization Error
In my one of database, I have synchronize all Database Logins successfully & its working perfectly.
But while synchronizing Windows logins I am getting a error:
Table 50007 does not exist.
Any one have any idea?
Which licence are you using?
Do you have permissions for this object?
check in table 2000000005
Have you copied role from some other database ?
Check if table 50007 exist or not
Okay, done.
Hi Shruti,
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you, so that we can see that your problem is now “resolved”. Otherwise let us know how you solved your problem.
Have a nice day! [:)]
