Synchronising large tables in Axapta
We will shortly need to synchronise some large tables in Axapta (2.5 Oracle) as we are adding some new fileds. We are afraid this will take considerable time and will require extensive disk space on the DB server. This is because axapta duplicates the table when synching and then moves data from the copy to a new table. We would prefer to simply add the fields using oracle ‘alter table add column’ and initialise it using update table. Is there any way of tricking Axapta into accepting a field added in this way to a table? Grzegorz
Hi, Try updating data model. Go to tools → Development tools → cross reference → Periodic → Update Cross-reference. Once there, enable ‘Update data model’ option. Hopefully this should meet your requirement. Regards, Harish Mohanbabu
