If a user opens a card form, browses through the records and then closes the form, the next time they open the form the record is positioned on the last record visited. I need to know if it is possible to effectively set the last visited record (as per stored in ZUP file) for a particular form through C/AL code. i.e. when a user closes one form, set the record position of another form which is based on the same table.
Any help appreciated,
Jonathan
