Swacha Bharath Cess in service Tax
Hi Experts,
I want to implement Swachh Bharath Cess in service Tax for my client. How can i proceed with this? Is it ok if i add new field in “Service Tax Setup” Table. If yes where i need to customize the code to get it effect correctly. What are all steps I need to follow before starting to modify?
Murali
Hello Murali,
If I am not mistaken then this tax started from this month only and as well as you need to consult with Tax consultant that how the effect of this tax will take on transactions and as well as on which transactions?
Will this calculate like ecess and SHECess in service tax ?
You need to understand all the effect and transactions before customizing the solutions .
Now this tax has been introduced then of course Navision partner who customized the localization in India will take care of this and will release the HF for the same
I would suggest kindly contact your partner for the same.
Thank you Amol,
Yes I will interact with user and also i need to discuss with my Senior colleauges I think.
Murali
