Supplier payment journal WONT show cheque number?
I want to know, which part of the setup for supplier payments triggers the payment journal to show a cheque number when your supplier method of payment is ‘cheque’?
I have configured a company in AX 2009 test and my BACs payment works fine but when I create a supplier payment it wont allocate a cheque number to the journal (it usually shows the cheque number on the journal screen at the bottom of the journal).
If someone can explain why or the setup I am missing that would be a great help!
K
On payment journal lines, did you click Finction > Generate payment and follow the step to create cheque?
Hi Khue,
yes I did do that. I know the process inside out but I am not too hot on the setup so I think I have missed a part of the setup out.
Its really frustrating and I am pretty unsure of where to go next. it allows me to choose a cheque it just doesnt show it on the Journal screen.
Thanks!
What is configured on the method of payment payment control tab for the method of payment cheque?
I have nothing selected here. Hopeing the less variables the more likely it would be to get it to show me the checque number!
So you want it to populate the cheque number without setting the correct entries - I am sure one of these is cheque number or bank reference or something - this is your issue, I do not have the software in front of me to verify this, but check the manual or help on this field!
Hi All - I have finally fixed the issue. I had a payment specification in for cheque and it was not needed. I took this out and it now works, I thought I had tried this before but obviously not.
Hope this helps others…
Thanks for your help Adam.
