Sum row of entries of an order
Hello!
Anyone know how I can write a method that takes all the rows of an order and counts a total sum for that order?
Simply write it as:
Select sum(field) from table // here, field is the amount which you want to calculate
where table.field1 == something // if any condition exists
info(strfmt(’%1’, table.field));
Actual Code:
you can create a display method under form datasource.
Take SalesTable as a example, there if you write under \Forms\SalesTable\Data Sources\SalesTable\Methods\totalLineAmount
here in above path “totalLineAmount” is the method which you are creating something like this:
display real totalLineAmount(SalesTable _sales)
Salesline line1;
Select sum(lineamount) from line1
where line1.SalesId == _sales.SalesId;
if (line1.LineAmount)
return line1.LineAmount;
else
return 0;
Once this is created you can drag it in to your form design.
lets say here : \Forms\SalesTable\Designs\Design[Group:Table][Tab:TabHeader][TabPage:TabHeaderOverview][Grid:GridHeader]\RealEdit:totalLineAmount
