Hi all, does not work the query written with the new syntax of AX 2012 and I do not know how to rewrite it: below is written in SQL and X ++ you tell me where am I wrong?
Thank you for your help
Mak5s
example SQL
select InventTable.BFItemLineId,
InventSum.ItemId,
InventDim.InventSizeId,
InventDim.InventSiteId,
InventDim.InventLocationId,
sum(PostedQty + Received- Deducted + Registered - Picked) as stockQty
sum(PostedValue),
sum(PostedQty),
sum(PhysicalValue),
sum(Received),
sum(Deducted)
from InventTable
inner
join InventSum
on InventSum.ItemId = InventTable.ItemId
inner
join InventDim
on InventDim.InventDimId = InventSum.InventDimId
group by InventTable.BFItemLineId,InventSum.ItemId, InventDim.InventSizeId, InventDim.InventSiteId, InventDim.InventLocationId
having sum(InventSum.PostedQty + InventSum.Received - InventSum.Deducted) <> 0
example X++
select InventSum.ItemId,
sum(locInventSum.PostedValue),
sum(locInventSum.PostedQty),
sum(locInventSum.PhysicalValue),
sum(locInventSum.Received),
sum(locInventSum.Deducted)
from locInventSum
where locInventSum.ItemId == locInventTable.ItemId
join locInventDim
where locInventDim.InventDimId == locInventSum.InventDimId
group by locInventTable.BFItemLineId, locInventSum.ItemId, locInventDim.InventSizeId, locInventDim.InventSiteId, locInventDim.InventLocationId
