Suddenly No Data in Critical on-hand inventory Report
I am facing an problem that generating critical on-hand inventory report with no data. I don’t have any customization on that report. Few days before, it starts to return no data every running even tried in all companies.
The report is located in Inventory management → Reports → On-hand. It can be ran successfully with correct data in DEV.
Is anybody encounter this problem before?
I am using R3 CU11.
Thanks MC
Do you really have the items with physical inventory less than the minimum quantity?
Have you tired to Debug (hoping you are a developer)?
Do other users have the issue?
Can you show us the setting of one item that should appear on the report in a screen shot?
If your code is well managed, you can see it in DEV, which means it should be fine. Do you have a QA box or UAT box, how do they look like? If they are all good, try to restart your production AOS instances after business hours.
Thanks for your answer, Kranthi and AdamRoue.
Your answer saves my life.
We use min. and max. for those frequently moving items and ware-housekeeper placed POs more than normal recently to fulfill upcoming peak season. So that’s why no data come out.
I tested increase the min. of one item and it can be shown in the report immediately.
