I have a PagePart on a Navision 2009 RTC Page and run the PagePart with the following SubFormLink:
Order No=FIELD(Order No.)
This works fine, but the now I want to alter the link because the relying data has changed. I want to achieve the following: I want the Link to show all Lines when Order No. ist met exactly OR when Order No meets the folowing Filter : Order No + ‘-’.
I write it as a SQL statement to make it more clear
SELECT * FROM tbl WHERE Order No = @OrderNoField OR Order NoLIKE @OrderNoField + ‘-’;
