When we use a subform with a link in the main form, if there are no record linked, the cursor set the focus on the sub form. If there is a record linked, all is OK. I try to activate one field in the main form but it doesn’t work. Can someone Help me for this probleme ? Stéphane VABOIS
When you set the property DelayedInsert to Yes on the Subform your problem should be solved. Regards, Reijer.
Yes, you are great…It works very well. Navision France Ask us that is it impossible. We 'll must add a new button to stay in Navision Corporate Stéphane VABOIS
Another option is to remove all Key-Fields from the subform. Reijer
Navison France is wrong. The only button you really need is a Button on the Quick-Link Bar of Internet Explorer which points to www.navision.net ------- With best regards from Switzerland Marcus Fabian
