I’m trying to set up a manufacturing subcontracting process for Galvanisation.
I have the subcontracting WC set up and the vendor linked, and operations in the Routing to use the subcontractor. The subcontracting worksheet works as expected.
We’re using Standard costing in this organisation, FYI.
We want to account for the Galv cost and the associated freight cost separately, so we’ve created GL accounts, and Gen.Prod.PG/Inv PG to suit.
I’ve created an Item for “Galv including freight” and added a production BOM with the Galv cost per kg and a transport cost per kg also - both as non-inventory items so we’re not managing stock. I’ve added that Item to the Prod BOM for the FG Item, with the correct units of measure and quantity.
For example:
We have a single piece Item to go for Galvanisation, weighing 100kg. I need to include the cost of 100kg of “galv including freight” in the production BOM for the parent item so it’s included in the standard production cost. I need to do this for multiple items btw, with different weights - it needs to be flexible so I was thinking of the BOM as the best place to record this cost.
At the moment, BC includes all the materials in the expected material cost, but not this Item - it therefore seems to treat it as a material variance every time.
If I use the item/cost on the Prod BOM, it shows as a material variance.
If I use the cost on the Purchase Order created by the subcontracting worksheet, it shows as a subcontracting variance.
I’m a bit lost tbh, I’ve been trying multiple options on this and I can’t see what to do - has anyone configured this scenario before please?
I’m sure there’s something simple I’m not doing…
