I am going to use a style sheet to generate a letter to a vendor. My user wants to update the Vendor Card when the letter has been generated. Does anyone have a suggestion on a good way to trigger this update?
Have you found an answer or solved your problem?
If yes, then I would hope that you would share the solution with the rest of the user group as I think many members would get value from the answer, so that we can close the topic and mark it as Answered.
If no, then maybe you can add a bit more information to the question, so that other members maybe are able to answer your question.
Thank you.
