Hi Experts, we have problem regarding Workflow, Actually when we deploy some customization from Test system to Production ,sometimes our Production system workflow become stuck, Although if we run Tutorial_WorkflowProcessor, it works fine, but users workflow did not work and become stuck. Please guide,
If it works when you run Tutorial_WorkflowProcessor, it suggest that you have a problem with the workflow batch job. Make sure it runs without errors and if not, pay attention to what’s wrong.
Unfortunately you forgot to attach a tag without your AX version and told us nothing about your deployment procedure. If it’s AX 2012, make sure that your procedure correctly updates CIL.
Thanks for your valuable suggestion,and sorry for not mentioned the Ax Version , we are using Ax 2012 R3,
