ameen
January 21, 2009, 11:08am
1
Hi ,
In structure card there is field called Header / Line .
when it gone to help it tells
Header/Line: Specify whether the Tax/Charge being defined, is applicable
for the Order/Lines or not. The various available types are:
• Header
• Line
i created a structure and i keep changing the values in the field Header / Line , but i could not find any differernce.
So could u explain what is the actual difference between these two .
Give practical example on this .
Thanks and regards
admin1
January 21, 2009, 4:58pm
2
Hi Ameen,
What is the Structure Card? If it’s functionality which is part of a localized version, then please tell us what country, then it will be easier for the other members to help you.
Thank you.
ameen
January 22, 2009, 3:37am
3
Thanks Erik,
My environment is Nav 4.0 sp3 IN Localization
Sorry to write like that.
In purcchase order / Sales order - there is a field called Structure .
When u go inside there is a field called Header / Line.
I am asking about this field.
I hope i explain this time what i am expecting .
Thanks and regards
