redrose
#1
Dear all,
I have one problem. I need to retrive a String Field,in which i need to apply a filter.
e.g My Field is having a data ‘61011701117’.and I have many records having similar data.
e.g ‘62011701117’.
‘63011701117’.
‘64011701118’. etc
I need to Retrive the records having the value ‘117’ from the position 4 to 6 .How can i do it?
Is there any way by which i can apply SETFILTER for the same purpose? please explain?
Regards
Rose
DaveT
#2
Hi Rose,
Did you try
MyRecord.SETFILTER( MyField, ‘???177*’ );
redrose
#3
Hi Dave
Its Working…Thanks a Lot…
Regards
Rose.[:)]
You can set a filter like:
‘???117???’
or it may be easier and faster to set a conditional test like
If Copystr(variable,4,3) <>117 then
Currreport.skip;
The ? act like a Place Holder in the filter, The Copystr function looks for a Starting Position (4) and the Numebr of characters that follow it (3).
Either way, Good luck Rose,
Alan
DaveT
#5
@ Rose
Glad to Help [:D] - Can you verify a solution to help others
@ Alan,
Yes this is also a solution but with the second one you will return a full record set which may have poor preformance.
