String Error while opening page requisition worksheet
While opening the page of Requistion Worksheet there is a error " The maximum length for a string value is 30. Page Edit Requistion Worksheet must be closed".
What is the solution of this error. This error does not occur on Requistion Worksheet Form.
Thanks in Advance,
Himanshu Kumar
Sounds like a code problem on the Page object. Do you have access to the debugger to see what line of code is throwing the error?
It is usually because one text (string) variable has a maximum value of 30, and a longer string is being assigned as its value.
Hi Matt,
I have no access to the dubugger to see the error code. Is there any other solution.
Himanshu
