Strange Subform
Hi All, I have a form with 3 Subforms. They all lie directly over each other (as in the main form 330). They all have the property visible set to false. Which subform is shown, depends on a field-value of actual record of the main form. This works fine, if i have a record an change the value of this field. The right subform is shown. But when i choose another record (page-up or page-down) sommetimes i see a black field where the subform should be shown. The Function which set the visible-properties of the subforms is called in the OnAfterGetRecord-Trigger. Can anyone tell me why no subform is shown, although the programmed code says that a subform should be shown??? Thanks in advance. Regards, Frank
Hi, If you select your record with the previous and next button , or with the search button , have you the same problem ?
Yes, i have the same problems [xx(]
quote:
I don’t understand because to help you i’m creating a new form sourcetable T27, i’ve just put 3 subforms of the menu principal and so test in the third char of the item no. to show one subform and i have no problem. Here is the code. Do you see a thing that you have done ? and not me ? Form - OnOpenForm() CurrForm.ContMgtMenu.VISIBLE(FALSE); CurrForm.HumanMenu.VISIBLE(FALSE); CurrForm.FAMenu.VISIBLE(FALSE); Form - OnAfterGetRecord() CASE COPYSTR(“No.”,3,1) OF ‘1’ : BEGIN CurrForm.ContMgtMenu.VISIBLE(FALSE); CurrForm.HumanMenu.VISIBLE(FALSE); CurrForm.FAMenu.VISIBLE(TRUE); END; ‘2’ : BEGIN CurrForm.ContMgtMenu.VISIBLE(FALSE); CurrForm.HumanMenu.VISIBLE(TRUE); CurrForm.FAMenu.VISIBLE(FALSE); END; ‘3’ : BEGIN CurrForm.ContMgtMenu.VISIBLE(TRUE); CurrForm.HumanMenu.VISIBLE(FALSE); CurrForm.FAMenu.VISIBLE(FALSE); END; END;
First of all thanks for your repleys!!! There are only 2 Differences: a) In order to save code, i first set to all subform visible := false and then with a case the right one to visible := true. But this doesn’t matter. Both version do not work in my case. b) my subform are on a pageframe and not on the first page. And this page is not the active one during changing the record. Maybe this is the problem??? Greetings, Frank
I try it with tabcontrol and so no problem Have you try to put a currform.UPDATE ?
Sure, but this does not help [:(] Is the tab with your subform active or is there another tab visible while choosing another record?
Hi, I’m fine you answer because tomorrow i’m going on holidays So i would like to help you I have put a subform in each tab (3) And so when i change the record the subforms is correctely visible or not, but obviously the tab whis not activate, so if you want you can put a .ACTIVATE
Hi and thanks for your help, i have one tab, where all three subform lie over each other. I can’t make three tabs, one for each subform, because of the style of the form. The User should not change to another subform, which is not active. Wish you a happy holiday. I have to work another 3 days…and then…holiday!!! [8D] Regards, Frank
With on tab it is ok too, Can you send me your form ?
Have you tried moving the code on OnAfterGetRecord to the OnNextRecord trigger?
quote:
Hi, If you do that, the trigger doesn’t work well
You’re right, it does not work on OnNextRecord trigger. I tested on OnAfterRecord and it works well for me, too.
