Strange CLR Interop issue
Hello,
I am receiving the runtime error, “Wrong arguments types in variable assignment”, when using the following code:
private str getFileDateTimeString()
System.DateTime dateTime = fileDateTime;
System.String outputFormat;
InteropPermission perm;
perm = new InteropPermission(InteropKind::ClrInterop); //<< Where error occurs
if (perm == null)
throw error(“CLR Interop error. You do not have sufficient permissions.”);
perm.assert();
outputFormat = CLRInterop::getObjectForAnyType(“YYYYMMDDHHMMSS”);
return dateTime.ToString(outputFormat);
Any thoughts on why and how I can get this code to run correctly?
Thank you!
Ok, so I rewrote this code to make it simpler and now it looks like this:
System.DateTime dt = DateTimeUtil::utcNow();
str s = dt.ToString(‘yyyyMMddHHmmss’);
return s;
The code above produces the same error! :frowning:
However, as a job it works:
static void dotNetTestDateFormat(Args _args)
info(strfmt("%1", s));
Any thoughts?
Well, this finally worked. Notice that I needed to make it static and assert the permissions:
public static str getFileDateTimeString(UTCDateTime _fileDateTime)
InteropPermission permission;
System.DateTime dt;
str sDate;
permission = new InteropPermission(InteropKind::ClrInterop);
permission.assert();
dt = Global::utcDateTime2SystemDateTime(_fileDateTime);
sDate = dt.ToString(‘yyyyMMddHHmmss’);
return sDate;
