Store Image
I want to store the Image inside the table :
For Ex:
if I have I Item Table
ItemNo ItemImage
pen Image
pencil Image
in this way i want store the images can anyone share their ideas abt this.
Thanks in advance…
you can use container data type with EDT set to Bitmap…
Arun.
Could you explain me detail with example.
Thanks for your reply,
Sunil kumar
in your example, the datatype of the field ItemImage should be as “container” and
Extended data type of that field should be as “Bitmap”.
Hope you understand.
  • Arun.
After that how can i store the image. How i can get the image into that field
Is it required any coding…?
I have extended the Bit map to my container field.
while creating record if i select container field its opening one more window there i can not choose any image how to archive this.
Regards
Sunil
hi,
you have to write code for that one…
use Inventory management-> Itemdetails → Setup button → Presentations → Image tab as a reference…
also see the CompanyImage form…
To store the image using container datatype try below steps:
  1. First to declare the binData and FilePath
Bindata binData = new BinData();
FilePath _path = ‘path of the image to store’;
  1. load the image file content to the binData object,
binData.loadFile(_path);
  1. Save to the table field which is a container type using below syntax,
binData.getData() → it will return the container type, you can directly store it to the table field.
Hope it will help you.
I hope it could help you
create a button to add image to your record.
add this method
void clicked()
str fileName = yourtable.CopyOfFileName;
#winapi
image image = new image();
Image::canLoad(fileName);
image.loadImage(fileName);
yourtable.imageContainer = image.getData(); //this inserts your image in your table (to the appropriate record)
yourtable.doUpdate();
yourtable_ds.reread();
yourtable_ds.refresh();
HI,### Store image in table
Create a table with Container Datatype
IN form take a method getImage() write the following code.
_path = “Image path”
void getImage()
FilePath _path;
ImageStore _ImageStore;
_path = “D:\India_flag.gif”; // file path
_ImageStore.ItemImage = binData.getData();
_ImageStore.doInsert();
__
take a button and call this method there:
void clicked()
super();
element.getImage();
ImageStore_ds.executeQuery();
HI Sunil,
I believe the best way to achieve it is to store image in CompanyImage table. For an instance, Try adding CompanyImage Display menu item on the CustTable form. Now when you open the CustTable form, you will be able to attach an image to the related customer record.
Hi Arun,
please check the following code.
static void Report_image(Args _args)
Image image = new Image();
str filename;
Report_image Report_image;
filename = “C:\Temp\Image.gif”;
image.loadImage(filename);
Report_image.Image = image.getData();
By using this code ,i am getting error like “file open failed”.
please help me out.
regards,
Murali.
