Store big text in tables.
Good day. one little question. How can i store text(greater than 250 symbols) in Navision Financials 2.60?? If I must use BLOB type of field - tell me how i must write & read text? Thank you.
Yes, u can use BLOB to save text file in it. You can open text file using notepad. You can use Rec.“BLOB Field”.IMPORT function to import file into BLOB field, EXPORT to export and SHELL to open it in notepad. I haven’t tried it but should work… -
