Stopped (error): Failed to create event handler object for class(class name) ax 2009
I am receiving the following error while the user rejects the workflow.
Stopped (error): Failed to create event handler object for class Event_handle_class_name
I am using ax 2009.
Check if the method returned or rejected is available in the Approval Event Handler class of your workflow.
Try generating incremental CIL.
We do have canceled method. and I am not sure if we can generate incremental CIL in ax 2009.
We have also written returned method.
Debug your workflow - it seems that your event handler class can’t be constructed (because of an exception, number of parameters or something).
CIL isn’t related to AX 2009.
Martin,
We have returned method written but we don’t have Denied method does that make any difference? I am attaching the snapshot of the workflow tracking details.
Don’t guess. Debug it.
Thank You Martin. I’ll debug it.
There was a parameter missing.
