Stopped (error): Element outcome Approve is not defined on the workflow element. in dynamics ax 2009
When iam processing Workflow for Purchrequisition getting this error…
while Resum record in Workflow History form…iam getting this error. …iam not getting solution for this…
Error : Stopped (error): Element outcome Approve is not defined on the workflow element.
checked workflow Approval also,
Pls Help me,
it’s live issue…pls give a solution
Priya
Hello Priya,
just to confirm the Work flow is set with all stages defined and assignments done.
For each workflow stage subject and notification defined.
try to remove the user from the workflow and add it back once,
is there any customization done on this template.
