Good day.
i would like to find out if it is possible to stop any journals from being posted if any of the financial dimensions are missing. i have tried setting up account structures but this on produces a warning in the infolog and still allows the journal to be posted.
what we would like to achieve is to completely halt the journal from being posted if any financial dimension is not entered.
Probably you need to revisit COA structure setup. Make sure dimensions are set as mandatory (allow blank is unchecked).
Pranav…
thank you for your reply.
we have setup the COA structures with specified allowed values and ‘Allow blanks’ unticked. when processing journals (eg. invoice journals) the user gets a warning info log that the dimensions are not valid but the journal still posts. could advanced rules be overriding this somehow?
