when I would do calculate generative planning from planning worksheet, I found the error the date is not valid. at discussion topic at the forum on the previous never discussed this issue, but did not answer the problems that I found
I have checked all the relating to the planned date, release and production firm plan, there no problems (missing date) and also has been examined through the debug, but the error still appears
Please advice if you ever run into problems like this and have found the best solution
many different ways I have done including, checking time register and be done with a different user, but still not found the solution. Is there another way I might not know and I have not tried it
