I have to create a new department Mainteinance in the department menu. I have also designed a page. How to attach new page in RTC.
Departments in the RTC are special types of menusuite objects. If you don’t already have a menusuite with a number over 1000, then you will need to create one. Hit F3 from the menusuite, or click New. At the top of the menusuite selection you can select to create a menusuite for the Classic Client or for the RTC. Select RTC in the level you need, and then you’re off, just add the page to the menusuite. For this to show up in the RTC you will need to restart the client.
