Startup Page
Hello,
I want to run a page on Navision RTC startup.
I have done code like this on codeunit 1 on CompanyOpen function:
IF ISSERVICETIER THEN BEGIN
CodeunitX.UpdateRoutine();
IF TableX.FINDFIRST THEN
FormX.RUN;
END;
This code runs well, but when RTC opens this page will be hidden for Navision main page. Is there a way to open this new page and put it on front, like a pop-up?
Hi, I have tried this solution in Nav 2009 RTC and it done well, but in Nav 2009 R2 RTC it not works. How can I run a page as a startup page? It works for form en Classic version, but do not work in RTC.
If it is only in RTC then write the code in
Page 9060 - SO Processor Activities(if you are using Order Processor Role Center )
OnAfterGetRecord()
PageX.RUN;
Hi, I heve tried this solution, but I just want to run this page once, and in this trigger it open the page every type I open the role center.
look at this post
http://mibuso.com/forum/viewtopic.php?f=32&t=47883
This issue should be fixed in the meantime by a hotifx released by MS.
A list of all available hotfixes for 2009 R2 can be found as this page:
Overview of Released Platform Hotfixes for Microsoft Dynamics NAV 2009 SP1 and Microsoft Dynamics NAV 2009 R2
